Mendes Index Out of Range error
  • Mendes Index Out of Range error
    I am getting an Index out of range error on a pair of lanes and am using a Mendes system. Had to turn the lanes on manually from the console for them to work. Any ideas how to remedy this?
    Will post a picture of the error when I can.
    Also, is there a Mendes troubleshooting guide somewhere that is digital to download?
    Thanks
    I don't know if they are still doing tech support, but try calling Allen Gaffer at 1-877-491-3769. They use to charge by the year for the codes to keep the system running.
    MONITOR COLOR ISSUE!!
    Pin spot is off
