Conqueror Pro BOOT 199
  • Conqueror Pro BOOT 199
    startup fails on
    *Test Lcd_L Mac found /timeout err
    Which scoring system is this? Conqueror pro is the management system.
    I would suggest moving LCD screen with another pair.
    Haven't actually done any welding for years, so I was up to the challenge when I found this machine that was having problem setting the head pin.
    Someone had welded this...
    Foul Light LED Mod
