Battery back up for hub?
  • Battery back up for hub?
    Has anyone tried putting a battery back up on besx hub on curtain wall? 3 times this week we had a power outage , that lasted for less than a second , then 7-10 min for everything to reboot . We have battery back up on front desk and server and was wondering if putting back ups on hub would work as well
    we put them on at all the Main Events and it stops the long reboot time
      You could put one on for each circuit at the first receptacle on the circuit. Of course, it wouldn't last as long, but I'd bet a 750 VA would get you up to 10 minutes.
        thanks for the input, ordering backups today
        Detector Rod Adjustment
        The New Brunswick NXT
