Fenice 28" monitor boards
  • Fenice 28" monitor boards
    Anyone have good boards or know of a source for repairing old boards. Thanks for any leads.
    Treat everyday like it could be your last day!
    Google Fenice 28" monitor boards, lots of results.
      ShaggyShawn give me a call when you get time !!!
        If you're interested in boards and monitors we just changed out 20 lanes of fenice.
          Rcole more info on what you have please
            Sorry about the delayed response but I hadn’t looked at my post for a while. Of the 20 monitors three have defective boards, four have color issues. The other thirteen were working properly when removed. I also have a spare tube and a few monitor boards that could also be repaired. In addition, I also have the original mounting hardware for paired units.
            Detector Rod Adjustment
            The New Brunswick NXT
