No Comms when starting Conqueror 1.76
  • No Comms when starting Conqueror 1.76
    My computer crashed and I had to rebuild the hard drive and now I get error message " It is not possible to get comboard data, check communications."
    Anyone have any idea on how to fix this?
    Thanks
    It means the ET host cannot be found on the conqueror network. It is tied in with a cat 5 to the switch. I would try to ping it once I found out what the IP is of your front desk. They do go bad, but they are also part of the license for Conqueror (that's why the error), so if you replace it, you'll need to get the new license from QAMF.
      I can ping the et host fine. I think I'm going to have to call qamf for help and get charged 2 arms and a leg
      The New Brunswick NXT
