no scoring
  • no scoring
    70's, mp's, Qubica conquerer version 2.05, t-vision.
    At the start of the league lane 8 would not read or recognize the first ball unless it was a strike, they had to manually enter the first ball. I changed the chassis with known good chassis, no change. Switched out the XLMP, no change. Checked the a&mc plug, pins in good shape and secure. Did camera check, all ten pins lined up and in focus. The teams bowling on that pair graciously said they would enter the score the rest of the night.
    After completion I checked all connections at the score table, ball return, and camera, Turned on the lane and had no scoring !st or 2nd ball, no strike, no graphics, nothing. What would have changed in that short of time? I paired the lanes as if in league play, 7 works fine, 8 would not register score and switch to alternate lane.
    Hope I've given enough info., any ideas what my next move should be?
    Check the pinsetter parameters (at the front desk) of a working lane and write them all down. Make sure that Lane 8 has all the same settings. If not, you can manually correct them or just copy all the parameters from a working pair.
      Good to hear ya Triac, I'll check those when I get in Wednesday morning. I quickly glance at them the other night and didn't see anything that jumped out, but I'll look closer.
        Have you tried rebooting/changing the v.b.d ?
          Are the ball sensors well adjusted and working?
          Detector Rod Adjustment
          The New Brunswick NXT
