Running old Conqueror in Win 10?
  • Running old Conqueror in Win 10?
    A while back I came across a post where someone said they were able to get a much older version of qubica conqueror to work on newer hardware and a newer operating system such as Windows 10. Has anyone been able to successfully do this? Currently we're running a much older version of conqueror and can't afford to upgrade at the moment. I would love to be able to use the old version of conqueror on newer hardware and a newer OS until we can afford the upgrade.
    I loaded Qubica on a 32 bit windows 10 OS and got stuck when it asked for a license even though i have the Qubica USB license.. It also argued that the MS SQL server 2005 is no longer supported but loaded anyway.You may have success if you can get Qubica help with licensing.However, during the ;last conversation I had about upgrades Qubica is not supporting Windows 10 yet on the latest version. They are selling it with Windows 7. Frustratingly, Windows 7 falls out of Microsoft support October 2020 I believe. If you have it on an XP 32 bit platform now you probably would have greater
    success sticking to a 32 bit operating system. Good luck.
      Windows 10 is fully supported on the latest versions of Conqueror
      Regards,
      Billy T
      bthompson@qubicaamf.us
        Thanks Bill that's great to hear!!
        The New Brunswick NXT
