Upper Monitor Issues
  • Upper Monitor Issues
    I'm not real familiar with the qubica scoring that I have. conquerer version 11.36 front desk I have F boxes, 3QT. on Brunswick A-2. Just lately I am having an issue with some of the upper monitors not coming on. seems to be the odd lanes if that matters. 5,9,11. most times I can reboot my 3 QT and they will come back up after a little while but not always. Lane 5 happens to be a newer monitor. they all are hooked in with S video cables if that matters. any ideas would be great thanks because im pretty certain that I am not cooking a monitor a day.
    If its still broken, guess it wasnt in the parts budget.
    Z
Detector Rod Adjustment
The New Brunswick NXT
