Tvision camers base
  • Tvision camers base
    Does anyone know where to get a camera base for a t4 camera board? Quibica np longer has them and cant tell me where to get one.
    Hi there
    you could try djc there a uk based company they may be able to help you. Here is a link to there website https://www.google.co.uk/url?sa=t&so...PyVanz0IgYkOxE
      I probably have one sitting here in Eagan, MN. Call Mike @ Stahls 651-322-2141.
      MONITOR COLOR ISSUE!!
      Pin spot is off
