Bowlandx keyboard issues
  • Bowlandx keyboard issues
    First off I have single oval keyboards.For whatever reason I have 3 pairs where I can only type on one lane. Neither lane selector lights up when pressed but they do beep still. So basically without hitting a lane selector i can type on 21 and if I switch the ribbon cable to the other keyboard slot on BT board I can type on 22. Ive tried swapping every component in the scoring system from one pair to a known working pair and the problem did not move. Any thoughts would be appreciated. Thanks
    lane setup needs to be setup for the correct keypad copy from a working pair and send
    The New Brunswick NXT
