Adjusting OKKIO V Camera
  • Adjusting OKKIO V Camera
    I am having trouble adjusting a new OKKIO V camera. I have tried following the instructions supplied with the camera but can not get a reading of 1 or 2 on the SX display. The instructions say to turn the encoder counterclockwise until the LED stops flashing. I have done this, then it says to rotate clockwise R16 until you have a value of 1 or 2 on the SX display. I don't see anything labeled R16 on the board only an adjustment labeled POT1. Rotating this adjustment seems to have no affect. I have T Vision 98 camera boards with M Vision software.
    Any suggestions would be appreciated.
    Gary
    Following, I have one camera like that in the same set up. It works but not whit the right setup. SX display to get the reading is done with a little push button
      I finally got the camera to count pins correctly but not by adjusting according to the instructions.
      We just kept making adjustments until the image looked good and it counted pins properly.
      Detector Rod Adjustment
      The New Brunswick NXT
