Electronic question
  • Electronic question
    We have Qubica scoring on partially converted A's. Started to replace TDMs with clear box encased relays like in a powerlift electrical box. There are only 3 wires going in and out of relay.
    When the machine triggers new relay sends a charge for only a couple seconds at most to seloniod. We are looking for a capacitor or something to hold the charge longer to the seloniod for 4- 5 seconds. Anyone have an idea? And would that capacitor go on the incoming power wire, or the outgoing ppwer wire?
    thanks
    Just curious why you want such a long pulse time?
    I remember someone mentioning that there's a setting in Qubica scoring to adjust this timing.
      I'm certain that the pulse is adjustable in the Qubica camera parameter setup. Been about 10 years since I last played around in the software setup, so I can't guide you. Hopefully someone will chip in soon to help you out.
        Your not going to be able to do this by just putting a capacitor across it. You will need a small time delay circuit, which is not a big deal. But I am also curious as to why you want such a long delay. I know as solenoids get weaker they don't react as fast but 2 seconds seems like it should be long enough. As soon as the clutch latch is pulled out, the solenoids job is done. You may be better off leaving the tdm board intact and have the scoring fire the tdm which will then give you a delay. I also agree there should be a setting to extend the trigger time in the scoring.
          Time delay boards are a antiquated part. They can be easily replaced by a simple cube relay. If you haven't the capacity to adjust the delay through your scoring system, you will need a timer relay. These relays are simple, cheap and easily sourced locally.
            Qubica Conqueror versions around 2 with Brunswick pinsetters and Six boxes have a place in pinsetter parameters to check a box for short pulse. Short pulse is supposed to be used with solenoids mounted on detectors. If you see a check mark in that box, uncheck it.
            Because the Qubica cycle signal goes into the time delay module the same way the reset buttons do, you will get the same pulse width with either a time delay module or relay.
              thanks
              Was that a typo? I think you need 2 low voltage wires and 2 high voltage wires on that relay.
                You are correct Me Badwrench. There are 4 wires. 3 on one side, one out the other.
                Only setting we could get through qubica was to have it keep pulsing until the seloniod triggers. It will pulse 2 seconds stop pulse again, stop...until it finally pulls clutch latch out. Sometimes takes 3 to 4 pulses to trigger. FM wants one long pulse to trigger. I will pass on what you told me to him
                .thanks
                  Have you looked at the solenoid adjustment including the vertical alignment between the plunger and connecting link?
                  You can rub a candle against the shaft of the plunger to reduce friction and aid response.
                    If you push the reset button at the rear of the pinsetter for half a second and it doesn't make the solenoid plunger pull in all the way you have something wrong. Either something mechanical is binding, a spring is too strong, or you wired a 208-240 volt solenoid up to 120 volts. Two seconds will overheat the solenoid during regular bowling.
                      Here is the procedure. And as James stated, alignment is critical to insure No Mechanical Binding which could burn up the coil or cause cycling problems. Keep all linkage well oiled and use the O-ring on the pin, not an x-washer.
                      Adjust Cycle Solenoid.pdf
                        You can also do that adjustment at 0. The only difference is you need to push down the actuator at the same time. I shoot for 1/16 when at 0, which gets you the 1/8 at 180. There is one other way, I just can't remember.
                          Thanks guys. I had to adjust a solenoid tonight. After I did, it stopped pulsing and triggered on first jolt. All the best,
                          Broken key
                          Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
                          Anyone wanting to have a guess at
                          A) Which...
                          MONITOR COLOR ISSUE!!
                          Pin spot is off
                          4" PVC BOW EXTENDERS
                          As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
