TV Mounting brackets
  • TV Mounting brackets
    It's been 5 years since BESZ install and our LG 42" flat screens are beginning to die. Somewhere in the replacement process I lost a pair of the mounting brackets that go on the back of the TV. To the best of my recollection everything except the TVs themselves came from Qubica.
    There is a rectangular mount that hangs from the ceiling. It came with mounting plates for the CPU. and there are two brackets for each TV that attach to the TV and basically hang the TV on the fixed mounting bracket. Does this sound like a Qubica item? Part #?
    Gen 4 Monitor Kit 612283003 ?????
      That's it!
        Glad to hear. The pictures of the other types I looked at were all big square plates. So hopefully your golden...
          We have a set on the way from Q
          Detector Rod Adjustment
          The New Brunswick NXT
