Static Issues
  • Static Issues
    Has anyone had issues with static knocking out cameras on the Conqueror Pro system??
    The only times I have suspected static was pinsetters cycling at random or failing to cycle.
      Do you have ISOLATED Grounds on ALL scoring equipment and is everything well grounded? May also want to look at high quality surge protection. I informed the owner of the center I formerly serviced to install surge protection. They never did. It has cost them about $5000 in blown circuit boards which ocurred when they lost power.
        When I was at AMF,we started gounding the cameras to the pinsetters to help prevent problems. We had old accuscore.
        Always remember rule #3,(Don't forget rule #1).Rule #1,see rule #3......
        MONITOR COLOR ISSUE!!
        Pin spot is off
