Quibica F-box Error 208
  • Quibica F-box Error 208
    What is it?
    Error 208 Impossible to communicate with F-Box (6)
    (6) The lane configuration needs an F-Box (Enhanced pinsetter interface) but it is impossible to
    communicate with it.
      I figured it would be something like that because the symptoms go along with a lack of communication. A hard reset brought it back. We'll see how it goes.
      MONITOR COLOR ISSUE!!
      Pin spot is off
