Bex X rebooting on it own
  • Bex X rebooting on it own
    Had a tournament bowling. One pair of lanes rebooted itself. Is this a common issue? What can i do? System is less that a year old.
    Thanks,
    Joey
    I've only worked on systems with VDBs, but that should not be common. If it only does it once, upload software from the front desk. If it does it again after that, swap the computer for that pair of lanes to another pair and see if the problem moves with the computer.
      Had a pair that would do it occasionally then it started doing regularly found a pinched wire going up by the accelerator
      Super Bowl Funday!
      Qubica BES-X Lane Advertising
      Making TDM's adjustable.
