chananging to tvs
  • chananging to tvs
    ive been having monitor troubles so we decided to try and switch to flat screen tvs
    of course or vdb are 9 pin so i got a 9 to 15 adapter plug but cant get any signal
    do i ned a convertor instead of the adaptor?
    Re: chananging to tvs
    If your vdb's are less than 5 yrs old it can be done. QA sells a lcd monitor for older vdb's.
      Since you have VDB93/96's at your center, you need to purchase the convertor from Q/AMF. If it was Bowland X or newer, you just would need a cable specifically pinned for that application.
        It looks awesome, you definately won't regret it!
          called qubica they told us the only convertor they had was a kit for 4000.00
          MONITOR COLOR ISSUE!!
          Pin spot is off
