Timer for Pinsetters
  • Timer for Pinsetters
    O.K. I already know that most will say to this is to get setter savers, but I will ask anyway. With the B.E.S. system is there a way to set it up so that the machines will turn off if the bowlers have taken an extended break? I remember that Frameworks was set up that way, but is it possible with B.E.S.? If so what are the steps?
    Ignorance is Bliss!
    Re: Timer for Pinsetters
    I have yet to see it. Nothing in the setup appears to have that ability.
      It should be possible if you got Conqueror Pro with 3QT's and F-boxes. I have that option here. The option can be found and activated under the "pinsetter parameters" screen in the technical setup.
      The older the part, the STRONGER it is.
        I am on vacation now but I will investigate that when I go back next week.
        Ignorance is Bliss!
          We have the BES system with 6-boxes. But thought I would check anyway, I didn't see anything there.
          Ignorance is Bliss!
            I have Conqueror Pro, 3QT's and F boxes and I don't see any option there. What is it called?
            Upgraded Motor Contactor
            C1 Pinout drawing
            Finished the C1 drawing.
            Thanks Felix.
            If you see any...
