upgradeing to 42' LCD need wire help
  • upgradeing to 42' LCD need wire help
    i am helping out a friend at his center. he buy 42" form visio. we tried them out they look good. our problem is the TV has no S-video input. the cable we got form AMF has S-video one end and other has 9 pin serial. we got an adapter S-video to RCA, it works. but the cable is on back order. we like to make own cables. not sure what the pin out is on VDB box. what i like is to get is ifno to make a cable to go form VDB to RCA. or better yet and if can be done is got form VBD to the component on the tv.
MONITOR COLOR ISSUE!!
Pin spot is off
