T-Vision camera
  • T-Vision camera
    I have a camera that i have readj 2x in 3 days.The camera is becoming misaligned and givin incorrect pincount.The interesting issue is that this particular camera was flipflopped with another pair to diagnose a ball detect issue earlier in the season.The camera needed readjusted after a few days.After about 2 weeks i put them back where they belong.Incidently, the ball detect problem disappeared on both pairs and now worried this other camera or board on original pair with no spare.I have checked mounting screws, hardware, wires, etc.
    Sounds like the lens is damaged or wobbly. If the lens is not solid it will become out of adjustment.
    - Albert Einstein
      What style of camera is it? ST900
      Marty - Pro Bowl West
      56 Jap A-2's Qubica VDB's
      2 Kustodian Walkers
        I have just a spare camera the model number is ST900, on the pair now is model:T Camera.Cant not get the ST 900 focused in cause of different configuration. Also, yes the camera does have a wobbly lens.
          Never heard of a model T camera. If the lens is loose on the ST900 camera, you can take it apart and tighten the screws on the inside of it, just need a good set of mini screwdrivers. And I assume you know the lens should not move at all.
          2 Kustodian Walkers
            Camera that is on the pair does have wobbly lens, yes sticker on back of camera says Model:T camera and has thicker bottom then ST 900 I have.I just left it on end pair for now, may later in week take advice and check for looseness inside of camera.
              I'm pretty sure work has these cameras, does it say Okio anywhere on it? And could you get a picture perhaps?
              Help-broken Part
              Greeting all.
              Thanks for looking.
              Bolton454
              Pin Damage
              Making TDM's adjustable.
              1:1 shaft wear
