upgrading tvs problem
  • upgrading tvs problem
    We r planning on buying new bigger flatscreen tvs to replace our current smaller flatscreens. Problem is ohrx3 converter board from qubica has the s video input and no one makes tvs with s video input. Anyone have a cheap fix or idea for this?
    The older the part, the STRONGER it is.
    I know twelve strike uses a svideo to hdmi converter for older systems to upgrade monitors so the box is out there somewhere - here is something from amazon.com
    http://www.amazon.com/Portta-PETCSHP.../dp/B003NS0UUQ
    Marty - Pro Bowl West
    Edit here - I see your problem is you have svideo coming out already from the Qubica box so I dont know if this would work without trying it. I would make a quess that qubica has something for a price.
    56 Jap A-2's Qubica VDB's
    2 Kustodian Walkers
      S-Video to composite adapter. Even new TVs have composite inputs.
      Super Bowl Funday!
      Qubica BES-X Lane Advertising
      Making TDM's adjustable.
