Substitute bowlers in league play. Focus
  • Substitute bowlers in league play. Focus
    Hey guys. Just got focus installed we used to have wins.
    We we are having an issue when we change a player in a league match. It's altering the handicap back to the first game. Manual days not to remove players but to use substitute button.
    The substitute button only seems to appear if the lanes have been started using the tournament program and not using the regular b11 bookings manager which is what we are using to put in our league matches into focus.
    Any my help would be greatly appreciated.
    Mark
    Mark,
    When you want to use a substitute, first make sure that you are NOT allowing the bowlers to edit names at the bowler console.
    We made a short tutorial on YouTube found here on how to use subs in leagues.
    https://www.youtube.com/watch?v=P-Dr...ature=youtu.be
    Additional frequently asked questions and Focus tutorials can be found here:
    http://steltronicusa.com/tutorials.html
    Thanks,
    Steltronic technical support
    Jim Osdale
    Steltronic USA
      Awesome Jim!!
      Thank You
      Mike Wilson
      Bowl-Tech Inc.
      Table support assembly
      Foul Light LED Mod
