Error incompatible hardware
  • Error incompatible hardware
    Why this happen?
    Help me plase..
    lublu bowling
    You might want to explain what this came out of.
      Looks like the message as the VLC boots up, connecting w/ the server. I would try un-plugging all connections except the server and the odd monitor, boot, and see if the same message comes up. Also, might want to confirm that the VLCs are being shut down correctly at night, don't just cut the power to them.
        There are several,reasons this will happen:
        1. The hard drive was cloned or imaged
        2. The VLC is configured for use with the Steltronic API, and the front desk pinsetter was set to a pinsetter that does not need an API, or vice-versa.
        3. Motherboard was changed, processor changed, or hardware conflict such as a USB thumb drive in installed.
        Jim Osdale
        Steltronic USA
        Pins getting gouged
