steltronic-MPloeder-v4.19-wins-
  • steltronic-MPloeder-v4.19-wins-
    Friends, what causes this problem?
    lublu bowling
    There is no problem..... that is what is displayed when your super elex's are booted up. The issue is if the screen stays like this; there is no communication between your super elex's and your server. The issue might be your hub/switch (depending what you have), or the Ethernet card is shot in the super elex, or the cat 5 wire is loose in the Ethernet port on the super elex, or loose in the switch/hub. Also check your ip settings on the server to see that pair of lanes match the ip on the super elex to the ip in the settings manager.
      Thank you.
      I will check what you say.
      The system freezes in this.
      lublu bowling
        There is no communication between your server computer and your super elex's. If you only have 4 lanes, it's most likely your hub/switch is kaput, or your Ethernet card might be kaput in your server computer. the system is not frozen.... there is simply no communication between your super elex's and your server
          Thank you so much
          lublu bowling
            Is 'win serv' even running? See if it's on the running on the task bar.
            Detector Rod Adjustment
            The New Brunswick NXT
