Focus Lite
  • Focus Lite
    please clarify whether the system has a Focus lite version of the restrictions on use with the system r-keeper v7? If not, please provide the manual for configuration.
    Hello Pavel,
    You will need to contact by email with your question.
    Jim Osdale
    Steltronic North America
    Jim Osdale
    Steltronic USA
    Haven't actually done any welding for years, so I was up to the challenge when I found this machine that was having problem setting the head pin.
    Someone had welded this...
    Foul Light LED Mod
