Strike Cycle
  • Strike Cycle
    Need help with the MCU SPEC Codes.
    We have gotten a new chassis and for some reason, it wont do a strike cycle.
    I can read the chassis settings at the MCU, but dont know what to change.
    Our machines are 82/90 xl and we have Wins 6.2.
    A list of all the Spec Codes that needs to be entered, is preferable
    82/90Xl and 82/90Xli
    Really....No one know this?
      I would assume by now the issue is resolved. But, just in case.............you might try the QubicaAMF in the Support section. If you don't have one, set up an account if I remember right it's free). Once there, go to the manuals section, and look for 610-005-700, which I think is the manual for the 82/90xl chassis. It gives the settings you probably are looking for. Good Luck.
      Leyton at Tahoe
        May want to call Steltronics directly. 909-971-9656 and ask for Jim Osdale He is very knowledgeable.
          Thanks for your reply.
          No i havent figured it out yet, but i already have the manuel, just need the configuration for Steltronic
            Perhaps that is the solution
            Super Bowl Funday!
            Qubica BES-X Lane Advertising
            Making TDM's adjustable.
