Cameras freezing up
  • Cameras freezing up
    We have a pair of lanes that the cameras have been freezing up. we would plugg and unplugg the connection at camera and computer, he have swapped cables put on some magnet deals on to help with static electricity. we have tried new camera, does anyone else out there have any tricks that worked for you. Strike 12 have been working on it. I'm sure they are just as frustrated as i am. any help would be appreciated.
    When this happened in one center, the neutral wire had a lose connection. Check the receptacle for the lane computer and the connection from where it's fed. And make sure the grounds are intact there as well.
      thanks i will try and look at that to make sure.
        Which version of 12 x do you have?
          Ryan has the new Windows version of scoring. I haven't suggested checking the electrical connections to ensure the are tight inside the outlet box, but that is a great suggestion as it has been a problem in the past as Ted indicated above.
            moved computer problem didnt fallow....Darryl sent a new cable so fingers crossed Thanks
              How did it go finally with the new cable
              Oil in gutters
              C1 Pinout drawing
              Finished the C1 drawing.
              Thanks Felix.
              If you see any...
