Camera losing image
  • Camera losing image
    I have a pair of lanes that once a day loses it image. The image goes black and white and all fuzzy. I have tried a new camera and have replaced the video card for the camera in the pedistal computer. I read on here that it could be a heat issue which I don't believe because I have opened up the panel in the back of the pedistal and have a flat screen monitor in it. I have pleanty of pedistals in may house with the old tube monitors in them and they are way hotter inside than this pair. I was wondering if anyone else had any ideas that can help me out.
    Replaced or swapped the Power supply?
    Swap the computer with another pair to see if problem moves.
    jonesborobowl.com
      We usually change the power supply when we change a camera.
      The New Brunswick NXT
