lane computers
  • lane computers
    Are the lane computers from different versions of Twelve Strike scoring interchangeable?
    Depends on when it was installed. Most DOS systems are interchangeable, but may have slightly different hardware (the hardware will work in all DOS as long as the cables will plug in, and adapter cables can be used if not). Most Windows systems are interchangeable, but may have slightly different hardware that may require specific external components (after all it is Windows).
      Thank you.
      Detector Rod Adjustment
      The New Brunswick NXT
