2017 Mechanic's Training School August
  • 2017 Mechanic's Training School August
    Stahl's Seventy's will hold second 82/70 Pinspotter training class this August. If you want to learn the easiest way to tear down, make adjustments, rebuild and troubleshoot your machines, this is the school for you! Limited spots available.
    Where: Farmington Lanes - Farmington, MN
    When: August 14th-18th, 2017 (9am - 5pm)
    If you are interested, please call us at 651-322-2141 to request a registration form.
    The August Pinspotter Training School is officially full!
    Pins getting gouged
