2018 Mechanic's Training School July 30 - August 3, 2018
  • 2018 Mechanic's Training School July 30 - August 3, 2018
    Stahl's Seventy's will hold second 82/70 Pinspotter training class this July. If you want to learn the easiest way to tear down, make adjustments, rebuild and troubleshoot your machines, this is the school for you! Limited spots available.
    Where: Farmington Lanes - Farmington, MN
    When: July 30 - August 3, 2018 (9am - 5pm)
    If you are interested, please call us at 651-322-2141 to request a registration form.
    http://tuffyparts.com
Detector Rod Adjustment
The New Brunswick NXT
