2015 Mechanic's Training School
  • 2015 Mechanic's Training School
    Stahl's Seventy's will hold one 82/70 Pinspotter training class this year. If you want to learn the easiest way to tear down, make adjustments, rebuild and troubleshoot your machines, this is the school for you! Limited spots available.
    Where: Apple Place Bowl - Apple Valley, MN
    When: July 13th -17th, 2014 (9am - 5pm)
    If you are interested, please call us at 651-322-2141 to request a registration form. For more information follow this link
    http://www.tuffyparts.com/2015%20Mec...20complete.pdf
    July School is Full!
      Stahl's Seventy's will hold second 82/70 Pinspotter training class this August. If you want to learn the easiest way to tear down, make adjustments, rebuild and troubleshoot your machines, this is the school for you! Limited spots available.
      When: August 17th -21st, 2015 (9am - 5pm)
      http://www.tuffyparts.com/2015%20Mechanic%20school%20complete%20august.pdf
      Pins getting gouged
