2016 Mechanic's Training School
  • 2016 Mechanic's Training School
    Stahl's Seventy's will hold one 82/70 Pinspotter training class this year. If you want to learn the easiest way to tear down, make adjustments, rebuild and troubleshoot your machines, this is the school for you! Limited spots available.
    Where: Farmington Lanes, Farmington, MN
    When: July 25th-29th, 2016 (9am - 5pm)
    If you are interested, please call us at 651-322-2141 to request a registration form. For more information follow this link
    http://www.tuffyparts.com/2016%20Mechanic%20school%20complete.pdf
    Our July class is now full. If anyone is interested in an August class, please inquire at 651-322-2141.
      Damn! I missed out again?
      Table support assembly
      Foul Light LED Mod
