2016 Mechanic's Training School
  • 2016 Mechanic's Training School
    Stahl's Seventy's will hold second 82/70 Pinspotter training class this August. If you want to learn the easiest way to tear down, make adjustments, rebuild and troubleshoot your machines, this is the school for you! Limited spots available.
    Where: Farmington Lanes - Farmington, MN
    When: August 8th-12th, 2016 (9am - 5pm)
    If you are interested, please call us at 651-322-2141 to request a registration form.
Pins getting gouged
