1 of 2 < >
No Replies to Posts
Special Instructions - Due to the nature of this forum we don't allow public replies to posts, please use the contact information in the post or send the originator a PM by clicking there their name select the activities tab and then click Private Message button.
Notice! - When making a post to this forum, it will be moderated and will not be visible until an Admin approves the post.
2 of 2 < >
Resume Tips - Keep It Simple (Click for more)
The right information in a resume will make or break the chances of being interviewed
A resume is skimmed by the reader in less than a minute… Keep it simple and to the point
See more
See less
Brunswick A2 Mechanic seeking work
  • Brunswick A2 Mechanic seeking work
    I’ve been a Brunswick mechanic since 1987, and I’m searching for a steady job. I’ve held all positions up to Mechanical Operations Supervisor at BRC. I’m familiar with A, Jetback, A2 converted, and factory A2 machines. Please let me know what you have. Thanks.
Detector Rod Adjustment
The New Brunswick NXT
