1 of 2 < >
No Replies to Posts
Special Instructions - Due to the nature of this forum we don't allow public replies to posts, please use the contact information in the post or send the originator a PM by clicking there their name select the activities tab and then click Private Message button.
Notice! - When making a post to this forum, it will be moderated and will not be visible until an Admin approves the post.
2 of 2 < >
Resume Tips - Keep It Simple (Click for more)
The right information in a resume will make or break the chances of being interviewed
A resume is skimmed by the reader in less than a minuteā€¦ Keep it simple and to the point
See more
See less
a2 mechanic 20+ years exp
  • a2 mechanic 20+ years exp
    Looking for an a2 house and am looking forward to relocating. I have over 20 years exp. I need a strong center with owner that has passion for the sport and not just the bottom line. I am very efficient at all aspects of facilities management/ building maintenance . I need 45k+ per year minimum. I am going to be on the road so call me instead of messaging 478-278-8029
    you know we don't allow managers back here....
MONITOR COLOR ISSUE!!
Pin spot is off
