No Replies to Posts
Special Instructions - Due to the nature of this forum we don't allow public replies to posts, please use the contact information in the post or send the originator a PM by clicking there their name select the activities tab and then click Private Message button.
Notice! - When making a post to this forum, it will be moderated and will not be visible until an Admin approves the post.
See more
See less
Chicago, IL - FT B-Mechanic and Pinchasers!!
  • Chicago, IL - FT B-Mechanic and Pinchasers!!
    Thriving at the bustling intersections of live music, chef-driven cuisine, nightlife, state-of-the-art gaming, and bowling, Lucky Strike has emerged as an industry leader in entertainment by crafting immersive, unforgettable experiences through timeless friendly service, one-of-a-kind atmosphere, chef-driven food and drink, and industry leading bowling.
    If you are looking to work with a dynamic team who shares your enthusiasm and passion for food, look no further, Lucky Strike is the place for you! We invite you to check us out!
    Lucky Strike CHICAGO is currently searching for a Full-Time B-Mechanic and Full- Time Pinchasers.
    DUTIES AND RESPONSIBILITIES:
    • Reports to the A Mechanic and General Manager.
    • Help to identify repairs needed on malfunctioning bowling equipment.
    • Assists employees in diagnosing malfunctioning equipment based on observation and the application of knowledge and experience.
    • Helps to and machine area is clean and organized at all times, e.g. workbench, work area, service aisle, etc.
    • Helps to performs all regular maintenance on all other club equipment.
    • Other duties may be assigned.
    EDUCATION AND/OR EXPERIENCE:
    • Experience in a mechanical role
    • Able to lift, push, and pull up to 50 pounds
    • Ability to work in an environment with high noise levels
    • Regular use of hands and fingers, tools, or controls; reach with hands and arms
    • Open availability, including weekend nights and holidays
    • Able to communicate in a clear and professional manner
    • Works well with others
    • Reliable, Trustworthy, Accountable and has a passion for customer service
    Stay Out of the gutter baby! Work for Lucky Strike!
    If you are interested, please reply with your resume to Michael.Ybarra@bowlluckystrike.com.
    Lucky Strike is an Equal Opportunity Employer
Detector Rod Adjustment
The New Brunswick NXT
