No Replies to Posts
Special Instructions - Due to the nature of this forum we don't allow public replies to posts, please use the contact information in the post or send the originator a PM by clicking there their name select the activities tab and then click Private Message button.
Notice! - When making a post to this forum, it will be moderated and will not be visible until an Admin approves the post.
See more
See less
NOVI, MI - B-Mechanics & Pinchasers!!
  • NOVI, MI - B-Mechanics & Pinchasers!!
    Thriving at the bustling intersections of live music, chef-driven cuisine, nightlife and bowling, Lucky Strike has emerged as an industry leader in entertainment by crafting immersive, unforgettable experiences through timeless friendly service, one-of-a-kind atmosphere, chef-driven food & drink, and industry leading bowling. If you are looking to work with a dynamic team who shares your enthusiasm and passion for hospitality, look no further, Lucky Strike is the place for you!
    Whether you are a seasoned professional in the hospitality field or just starting your career in the industry, we invite you to check us out!
    Lucky Strike is currently searching for B-MECHANICS & PINCHASERS for our venue in NOVI:
    DUTIES AND RESPONSIBILITIES:
    • Reports to the A Mechanic and General Manager.
    • Helps to identify repairs needed on malfunctioning bowling equipment.
    • Assists employees in diagnosing malfunctioning equipment based on observation and the application of knowledge and experience.
    • Helps to and machine area is clean and organized at all times, e.g. workbench, work area, service aisle, etc.
    • Helps to performs all regular maintenance on all other club equipment.
    • Other duties may be assigned.
    EDUCATION AND/OR EXPERIENCE:
    • Experience in a mechanical role
    • Able to lift, push, and pull up to 50 pounds
    • Ability to work in an environment with high noise levels
    • Regular use of hands and fingers, tools, or controls; reach with hands and arms
    • Open availability, including weekend nights and holidays
    • Able to communicate in a clear and professional manner
    • Works well with others
    • Reliable, Trustworthy, Accountable and has a passion for customer service
    If interested, please send your resume and availability to Ashley.Schachinger@luckystrikesocial.com OR Michael.Ybarra@luckystrikesocial.com
    Lucky Strike is an Equal Opportunity Employer
Detector Rod Adjustment
The New Brunswick NXT
