No Replies to Posts
Special Instructions - Due to the nature of this forum we don't allow public replies to posts, please use the contact information in the post or send the originator a PM by clicking there their name select the activities tab and then click Private Message button.
Notice! - When making a post to this forum, it will be moderated and will not be visible until an Admin approves the post.
See more
See less
Frames Bowling Lounge in NYC Seeking B Mechanic ASAP!
  • Frames Bowling Lounge in NYC Seeking B Mechanic ASAP!
    Frames Bowling Lounge NYC is currently searching for Full-Time B-Mechanic.
    DUTIES AND RESPONSIBILITIES:
    • Reports to the A Mechanic and General Manager.
    • Help to identify repairs needed on malfunctioning bowling equipment.
    • Assists employees in diagnosing malfunctioning equipment based on observation and the application of knowledge and experience.
    • Helps to and machine area is clean and organized at all times, e.g. workbench, work area, service aisle, etc.
    • Helps to performs all regular maintenance on all other club equipment.
    • Other duties may be assigned.
    EDUCATION AND/OR EXPERIENCE:
    • One or more related experience on Brunswick A-2 machines; or equivalent combination, education and experience.
    • Proficiency with Steltronics
    • Able to lift, push, and pull up to 50 pounds
    • Ability to work in an environment with high noise levels
    • Regular use of hands and fingers, tools, or controls; reach with hands and arms
    • Open availability, including weekend nights and holidays
    • Able to communicate in a clear and professional manner
    • Works well with others
    • Reliable, Trustworthy, Accountable and has a passion for customer service
    Willing to pay for relocation!
    Competitive Salary!
    Email scott@framesnyc.com
    ALSO LOOKING FOR PINCHASERS!
Detector Rod Adjustment
The New Brunswick NXT
