No Replies to Posts
Special Instructions - Due to the nature of this forum we don't allow public replies to posts, please use the contact information in the post or send the originator a PM by clicking there their name select the activities tab and then click Private Message button.
Notice! - When making a post to this forum, it will be moderated and will not be visible until an Admin approves the post.
See more
See less
JOB OPENING FOR FULL TIME HEAD MECHANIC
  • JOB OPENING FOR FULL TIME HEAD MECHANIC
    Seeking a talented mechanic for our busy Wayne, New Jersey center. We have well working AMF 8290 machines, Qubica scoring, Kegel lane machine. It is a 45-50 hour work week, some nites, some weekend shifts, some days. We are looking for schedule flexibility based on our business demands plus time to do preventive maintenance. Salary range is $45,000 to $60,000+ depending on experience and abilities. Demonstrated facility management and staff oversight skills a definite plus. Great work environment, 401K, employee discounts. Willing to give a strong assistant B mechanic the opportunity to grow with us as well so take the next step in your career!
    You may reply to me on this site or send me a resume and contact information directly at [email protected].
Bind in deck hook linkage
GS-X table bolts/stud
Other that...
