No Replies to Posts
Special Instructions - Due to the nature of this forum we don't allow public replies to posts, please use the contact information in the post or send the originator a PM by clicking there their name select the activities tab and then click Private Message button.
See more
See less
Foul lights needed
  • Foul lights needed
    I have a 6 lane center with AMF 82-70s, above ground ball returns, and Accuscore automatic scoring. The foul lights haven't worked in 30+ years. I was looking at new Zot units, and it would cost me $2000 for the 4 units I need. Are there any used units available or does anyone have any suggestions for a better priced option? I don't need them to tie into the scoring or reset the machine. I just want them to buzz when someone fouls.
    Thank you,
    Jeremy Brenner
Detector Rod Adjustment
The New Brunswick NXT
