oil filter
  • oil filter
    what kind of oil filter are you useing on your a-22 bruns or something deferent?
    We are using original from our dealer of brunswick :-)
      Filter ?? Got me on that one...
      "Don't expect too much and you'll never be let down..."
        There is a screw-on oil filter in both the A-22 and the Envoy that is recommended to be changed once a year or whenever you change from one oil to another. It's similar to the filters for cars.
        There is also a mesh screen filter in a bowl fitting near the oil pump on these machines that can be removed and cleaned or replaced. I assume that papajohn was referring to the screw-on filter in the original post. He might be looking to see if that is available at the local auto parts store.
        The New Brunswick NXT
