envoy cleaner pressure
  • envoy cleaner pressure
    What's the proper cleaner pressure on the envoy? Using invincible 4:1 and currently have it set on 21 when you activate the cleaner pump in the cleaning diagnostic menu, getting around 20 lanes per tank refill in the machine
    Ware using Max 10 20:1 our pressure is 18 (book calls for 16-19) we can clean 30 lanes. I check my pressure when I put machine on lane & it sprays for 6 seconds with hood open
    Table support assembly
    Foul Light LED Mod
