A22 Conditioner Values
  • A22 Conditioner Values
    Hi Guys
    Does anyone have the conditioner values for Kegel Navigate?
    You can call Brunswick Technical at 800-937-2695. They may have the info you want.
      I'm sure you've got it by now, but for anyone searching:
      Navigate A-22 values: 17 31 46 62 60
      MONITOR COLOR ISSUE!!
      Pin spot is off
