A22,conditioner pressure is too high
  • A22,conditioner pressure is too high
    Hy all.i have a problem with my a22.
    machine gives me error "the oil pressure is not set properly.oil pressure is to high" i checkede wires betwen oil pressure sensor and board,and oil pressure valve is good to i checked it also.I dont have idea what to do.if you have any tips please tell me.
    Here is some pics
      Is there any chance that i have motherboard with failure ??? Everything in machine is ok.whats happend when pressure sensor is broken ???
        whic pressure must be in the bladder (accumulator)??????
          If your analog gauge is reading high, then you do have a high pressure problem and you can eliminate the sensor as it is also reading high. If the analog is reading normal then it may be possible the pressure sensor is defective and giving a false input.
            10 psi. If to high, that may be your problem. If you get oil coming out when you are checking the pressure, the bladder inside the accumulator has ruptured and will need replaced.
              Table support assembly
              Foul Light LED Mod
