We just bought an Envoy
  • We just bought an Envoy
    We use a Kegel machine lift to lift our old Phoenix. Is there some kind of adapter that will let us lift the Envoy?
    Thanks
    John
    John
    Honestly doubt it. Either call Brunswick and see what they say, or you should be able to find a sling used in other industries that will maintain the balance and control of the Envoy
      Just opened the box. No place to put an eye bolt, but can put an axel strap on the lifting handle. Now I am happy. Funny, I tried to contact Kegel, but thier email doesn't work from Canada. I did find an email site, but no response. I really liked the service I got from them in the past, but no help here.
      John
        I bough 2 X 2ft straps with D rings on each end. Works great with machine lift. Just slide them thru handle and hook to lift.
        I love the lift but straps were too short for ENVOY. 2Ft straps did the trick.
        So far, ENVOY works great too.
        John
          Good deal
          Before and After
          Pins getting gouged
