Removal/Installation instructions for Envoy?
  • Removal/Installation instructions for Envoy?
    Does anyone have removal and installation instructions for the Envoy? I've already had to swap out both pumps, the buffer belt and an injector and I waste a lot of time having to figure these out. The manual doesn't help much so I'm hoping someone on here has instructions. Anything will help. Thanks!
    Is this what you're looking for or is this what you already have?
    http://www.brunswickbowling.com/down...Rev_1-13_1.pdf
      I already have this manual. It lacks a lot of instruction for the replacement of parts such as the injectors, injector rail, buffer brush belt, electronic troubleshooting, etc.
        Spray*
        • Travis75
          graffiti removal
          Travis75
          Has anyone out there got any solutions for removing spray paint graffiti? I have tried 2 different products from home depot, the problem with them is, that our building is made...
          04-11-2007, 08:28 PM
        • spinbowl
          2 to 1 removal
          spinbowl
          This is my first 2 to 1 removal. I downloaded the 2 to 1 removal instructions from here and have a question about step D. is the selector cam follower mentioned here what I...
          12-26-2006, 01:21 PM
        Detector Rod Adjustment
        The New Brunswick NXT
