Oil Pressure
  • Oil Pressure
    What should be the correct Oil Pressure setting in the A22?
    I'm at home now but I want to say it should go about 10-15psi then up to 30, then maybe down to 25 on the way down the lane. I'll check my book when I get to work tomorrow.
      Here is the page I got from Brunswick.
      Super Bowl Funday!
      Qubica BES-X Lane Advertising
      Making TDM's adjustable.
