BCU2 section Of 6 Acting Up
  • BCU2 section Of 6 Acting Up
    Hi Guys I got All My BCU2 installed 1 thru 60 and I have a section from 41thru 47 lights flashing green and red so when I turn on the bumper they won’t event go up. They work ok if I do it manually. It looks like they are for some reason off line. thank you and advance for any inputs.
    Smile Jesus loves you
    By BCU2, do you mean Qubica Bumper 2 or 3 (QB2/3 )? how does your BCU2 interface with scoring?The BCU unit should interface the scorer's LCOM to the air valve solenoids, You might also check to see if the 12 volt power supply for the solenoids can handle the current load. We had to replace the stock one with a higher rated one. And of course recheck wiring.
    Always remember rule #3,(Don't forget rule #1).Rule #1,see rule #3......
      I already have checked wiring, switch with a working one so I know for sure it doesn’t has to do with a bad wiring or bad Interface, my power supply is ok because all the other lanes 1 thru 30 is working ok.
      The only thing I am thinking is if connecting my bumpers 1-30 and then I Skipped my middle section, because those Are our busy lanes, I continued with 60 down as soon as Get to 49 I got all other 4 of my BCU2 flashing red and green. I am wondering if that cause my conqueror to reprogram the higher end first and mixt up the Adresses of each BCU2. I read that I am suppose to install then in order from lowest to high number. Let me know if any body has any I diea about it.
      and if so how can I reset the information in my conqueror.
      before Hand thank you for all your inputs.
        You may be right, could be a IP address issue. You might check with Pat at QAMF tech support. I have found her to be very helpful many times.Or try the QAMF customer portal.
          One power supply will not power that many lanes. Should have a power supply for every 8 pairs
          Regards,
          Billy T
          bthompson@qubicaamf.us
            Found this: https://www.qubicaamf.com/customerpo...a6717d615a.pdf ,
            hope it might help.
              Hi Guys,
              thanks For all your inputs
              I just wanted to come back and thanks everybody and also post what I found for future reference. What it ended up being was a defective charger for that section when We measured voltage with our voltmeter it was lower than 12v. And still dropped even lower when is not suppose to.
              And even though we desconected all the interfaces to left only one still gave me the same flashing, green and red, issue. Changed the defective charger with a new one and Bingo! Problem solved.
              Thanks everyone I hope this post would help anybody else that may encounter something similar.
              Thanks again
                That error info is a good thing to know about. Glad you found and shared info.
                Before and After
                Pins getting gouged
