quibica pneumatic bumpers questions
  • quibica pneumatic bumpers questions
    I have some non functioning qubica bumpers...there are missing cylinders as well as mounts, plus there are cracks in the gutters...from what I am told, they have not worked for a long time...I like the concept of how they are designed to go up and down with the needs of the bowlers...however, the curve or radius of the gutters are so shallow, that if anyone throws a ball above 10 mph, the ball flies out and hits the machinery...sometimes damaging both the ball and the machine...if I oil the gutters, it helps, but doesn't cure the problem...this makes me hesitant to give out these lanes at all, and with only 8 lanes, I am losing a quarter of my capacity...I am looking for ideas, suggestions, any input I can make use of...should I pay to have these fixed? is there a resource to buy used gutters and bumper systems? I would rather switch back to normal gutters, with the simple rails that pop inward when released...I currently use carpet tubes as bumpers...very high tech :-)
    thanks again!
    We'v had them for 20 years. Had balls going through the masking unit since day 1. Nothing but problems.
    Have tried all sorts of bandaid fixes. The best one was to raise the capping and divisions by at least a inch. This cut down on balls taking out the scoring camera and significantly reduced ball damage due to balls hitting the machinery but we have never fully fixed the problem.
      What's causing the ball to jump out of the gutter besides the shallow curvature. I know when they installed ours, they set them below the flat gutters so when the ball hit the flat gutter it would cause the ball to jump up into the rake arm causing ball damage. Does this happen at a specific point, is it related to where the ball goes into the gutter or some other point of exit.
      Maybe some pictures of what you have might help.
        I have found that on install the deadening material has been removed, which puts unsupported areas between cribbing. This is most critical in the last 8 feet before the pin deck, which causes the ball to bounce and the gutter to crack. I have had mine for 15 years, changed a few brackets on the air cylinders (all the parts are available still from AMF) but love them. HP has a good move in raising the edges. You mentioned the "shallow", peaked my interest, so compared gutter and bumper rail to o/e wood, not that much difference. So pull up one set and see what is under them.
          actually the balls rock back and forth all the way down the gutter...if there is enough angle and speed, the ball loops all the way out...especially when missing a ten pin. if I oil the gutters, the amount of swing is reduced, but not enough..and you can easily see that the curve of these gutters are much shallower than the curve of the regular gutters...seems like if I were to lower the gutters, or raise the caps, that then the balls would be hitting the edges of the caps, and possible damaging the balls...or the caps....I will work to get some pictures...thanks again!
            my capping seems to extend over my gutters. I havent had any issues with balls coming out
            If its still broken, guess it wasnt in the parts budget.
            Z
              are the cylinders operated by air compressor , if the cylinders are not mounted ,that will cause the gutters not lay flat
                we have bumpers that is controlled by air compressor ,we have to repair the bumpers ever week ,repairing isn't hard they just keep cracking
                  we dont hand out bumpers to anyone that is older than 10 or handicapped. It has cut down on bumper repair majorly. If you can chuck a 12 lb ball you don't need bumpers in my opinion
                  Z
                    I'm guessing those are AMF clear bumpers. The clear ones are more brittle than the older gray ones. And a lot worse than any Qubica bumpers I've seen.
                      currently going with zbowl...only little ones, and older folks...trouble is, that's 25 percent of my 8 lanes...plus I have to put tubes in a lane for bumpers...so...I am working on getting a set of regular gutters, with simple bumper rails...always preferred the ones where you release a lever, the bumper rails pop out...return by overcoming the spring, and click into place...just sayin...
                        I am totally pumped to have found a pair of lanes worth of gutters with rail type bumpers...pull back to raise, push forward to drop...plastic...easily removed from pacific lanes in Tacoma...a really nice 36 lane house that just closed...trouble is, I am not sure how to remove the qubica air powered bumpers in my place...don't mind trashing them to remove, but don't want to damage anything else...any tips would be greatly appreciated!
                          riverview scott are you involved in the teardown of Pacific Lanes?
                          Member Date 08/17/01
                          FlyDelta
                            I just bought some bumper/gutters from them for two lanes...watched the team doing the teardown...hard to watch a fully functioning bowling alley get turned into apartments, but that's the way of things now...
                              for the life of me, I cant seem to get the old bumpers out easily...I may have to destroy my way out....
                              • Mechanick
                                Problems with balls jumping out of the gutters
                                by Mechanick
                                There has always been a problem here with balls jumping out of the gutters. It happens on the lanes with the metal VOS V-shaped gutters we have here...but it is expecially a problem...
                                02-23-2011, 04:29 PM
                              • Guest's Avatar
                                VOS Gutters and cappings
                                by Guest
                                VOS gutters and cappings are notorious for taking nicks out of balls .I have managed to overcome problems with the gutter joins but I am looking for suggestions as to the cappings....
                                02-19-2000, 05:56 AM
                              • brentman1
                                Surface returns-ball jumping out of gutters
                                by brentman1
                                A friend has just installed Amf scoring w/ cameras and is having problems with balls jumping out of gutters and hitting cameras and damaging the balls. This pair of lanes has...
                                11-01-2010, 04:56 PM
                              • PKMech
                                Ball Detect Protector
                                by PKMech
                                I saw a thread a while back about a protector for the ball detects. Couldn't find it in the search. In short we have Brunswick capping and Qubica gutters. The funding...
                                08-01-2012, 10:02 PM
                              • Guest's Avatar
                                Ball Damage
                                by Guest
                                I seem to have a problem of balls bouncing out of the flat gutters. Everything is tight, heights are good, new edge boards and good plates. This problem occurs across the house...
                                06-23-2000, 05:47 AM
                              Broken key
                              Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
                              Anyone wanting to have a guess at
                              A) Which...
                              MONITOR COLOR ISSUE!!
                              Pin spot is off
                              4" PVC BOW EXTENDERS
                              As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
